Order Farmall Cub Parts Online
Power Take off on Cub What to do next
Farmall Ed
06-20-2007 13:49:48
The sliding clutch seems to be working fine,but as soon as you put a load on it, it will pop out of gear. There is a little play back and forth in the shaft. Do I need to replace the bearing at the rear plate? Or what do I need to do. All suggestions will be appreciated. Thanks Ed
Roger46
06-20-2007 19:38:11
 Re: Power Take off on Cub What to do next in reply to Farmall Ed, 06-20-2007 13:49:48
There are several things to cause the PTO of a Cub to slip out. It could be the ball detent, worn shifter, bad bearing, bad splines (what I had on mine and ended up replacing the transmission shaft). You need to take it out and see which of these things is the major cause. Roger
