PTO Quit!!!!!
wildturkey69
06-20-2007 17:22:36
While running the haybine with my farmall 400, hit a large ground hog hole and the pto stopped working! Any tips or suggestions???
Hayfarmer
06-20-2007 18:00:16
 Re: PTO Quit!!!!! in reply to wildturkey69, 06-20-2007 17:22:36
If it is like my SMTA pto there is a seasonal disconnect under the torque tube, perhaps it turned or broke coupler. Otherwise check linkage to pto housing in back. Check to see if you can turn shaft by hand with pto engaged, if so is probably a problem in the pto rear housing.
wildturkey69
06-21-2007 08:46:24
 Re: PTO Quit!!!!! in reply to Hayfarmer, 06-20-2007 18:00:16
Hayfarmer, It was the seasonal throw out switch, but it jumped the groove on the "spider" gear and had to be set up again! It was a pain and messy but I managed to get it aligned. I appreciated your help!! Back to making hay, thanks to you!!
Steve
wildturkey69
06-21-2007 04:53:14
Thanks!!!
