Farmall H brakes?
Aaron B
06-20-2007 22:23:52
I have what is probably a dumb question for you guys. On the bottom of the brake covers of my H, there is an adjustment bolt with a nut to lock it in position. What is this supposed to do? All I can think is that the bolt pushes up on the brake band, but don't understand why it would have to do that. Also, I would be curious as to how I should properly set these bolts, once I learn their purpose. Thanks!
Aaron
Wayne Swenson
06-21-2007 05:58:09
 Re: Farmall H brakes? in reply to Aaron B, 06-20-2007 22:23:52
third party image
The purpose of the set screw is to help center the brake band and lessen the rubbing and wear when the brake is released. I adjust mine this way: apply the brakes firmly and lock them. Loosen the lock nut, turn the screw in fully and back out ½ turn, relock the nut and you are done.
Thomas D Windsor
06-21-2007 11:51:21
 Re: Farmall H brakes? in reply to Wayne Swenson, 06-21-2007 05:58:09
Yep, I guess that is the reason they print up a book. When I looked at it...it seemed to be for no useful purpose. See, Old dogs do learn new tricks.
TW
randy hall
06-21-2007 05:23:23
that screw is to keep the brake band from rubbing on the top of the brake drum all the time. you screw it in tight then back it out a turn and lock the nut.
John Blanc
06-21-2007 03:29:58
If you look in the manual to adjust brakes it explains exactly what that bolt/lock nut is used for. You will need an operators manual for a restoration project as well as safe operation of your tractor. Good luck with your project. Dick
Aaron B
06-20-2007 23:09:12
If it were a drain plug, I would think it should just be open to drain. I had to replace the pinion seals as well as the oil-saturated brake bands due to leaky seals. I just would like to know what their purpose is, as I am totally restoring the tractor, and don't care to have ongoing issues after I put it back together.
Thomas D Windsor
06-20-2007 22:33:13
Aaron
That thing does not adjust anything. I have had the covers off and looked at the item that you speak about. The best I can figure, it is maybe a drain plug.
TW
