Super MD Head Cracked
AGR538
06-22-2007 08:58:23
I have a cracked head on a Super MD. Has anyone had luck having the cracks welded? I was told to go to a head shop in Caruthersville, MO. Any advice is appreciated.
henryv1111
06-23-2007 06:38:07
 Re: Super MD Head Cracked in reply to AGR538, 06-22-2007 08:58:23
Chapin Cyl Head is the best we have found. They do a good job. They might have a head in stock for you. Then you give them yours for exchange plus the cost of repair.
steelfronts
06-22-2007 17:45:08
Chapin Cyl Head 782 cyl head road
Chapin Ill 62628 217 472 3151
Did some gas start diesel heads for me cost about $1000 Did a good job
the Unforgiven
06-22-2007 11:46:01
Hi AGR, There is a shop in Lincoln NE that is doing some spectacular work with cast iron, I have seen some IH diesel heads in his shop. A lot of the big welding shops here will send a job like yours to him. He has a very good understanding of cast iron, which is very hard to find. Very expensive, usually not in a hurry, and he gaurentees his work. I will send his contact info if you are interested.
