Where to add oil
Levy
05-30-1999 13:13:48
I found out from previous posts how to check the oil level in my H, but I still can't figure out where to add it!? thanks, Levy
The Red
05-30-1999 13:22:13
 Re: Where to add oil in reply to Levy, 05-30-1999 13:13:48
Levy stand on the distributor side of the H. Look 5 inches to the right and you will see a 3 1/4 inch diameter cap with a wing on it, if original. It may be a flat plate with a bolt in the middle. Turn it counterclockwise and remove and add 6 quarts of oil. The oil actually pours through the timing gear cover into the oil pan.
Levy
05-30-1999 13:38:19
 Re: Re: Where to add oil in reply to The Red, 05-30-1999 13:22:13
Thanks Red. What's the vertical canister to the left?
RKS
05-30-1999 13:42:50
 Re: Re: Re: Where to add oil in reply to Levy, 05-30-1999 13:38:19
it's the oil filter cartridge cover (holder), when you change oil, remove the bolt on top and take the filter cover off. "I do Red's lite answer work." RKS
The Red. Also Levy
05-30-1999 14:12:48
 Re: Re: Re: Re: Where to add oil in reply to RKS, 05-30-1999 13:42:50
There is a little square nut in the bottom of the oil filter assembly. If its not torn up, unscrew that to drain 2 or 3 tablespoons of oil before removing the cover. The big nut takes a 7/8 inch wrench on that nut.
When you change the oil filter, take the time to dig out the old rubber gasket that the can squeezes onto. A new gasket should come with your filter. You don't have to replace it each time, but the one in there may be ancient.
mj delaney
05-31-1999 05:09:10
 Re: Re: Re: Re: Re: Where to add oil in reply to The Red. Also Levy, 05-30-1999 14:12:48
When changing the oil filter which should be done every 100 hrs or so, take the time to make sure the canister is properly seated in the groove where the rubber gasket is positioned; this can be tricky and result in a persistant leak if you don't get it right. There is always a danger of overtightening too. On top of the canister there should also be a copper sealing ring where the bolt goes through. Obviously, if you change the filter, you should change the oil. I assume this tractor has been using detergent oil. If not, there can be concerns with sludge. I assume the engine is clean and sludge free inside?
Carol Thornton
09-12-2004 13:42:25
 Re: Re: Re: Re: Re: Re: Where to add oil in reply to mj delaney, 05-31-1999 05:09:10
Hi,
I have a Farmall 400 Torque Amplified (gasoline model) and wanted to know where to add the oil and what type of oil?
Greg M-Suggest a Manual
05-30-1999 21:42:04
When I started working on my H I bought an operator's manual and a service manual. These have been very helpful and I consider them a must if you plan on doing any maintenance on the H.
