2-14 plow
Andy Glines
06-05-1999 23:04:49
I just bought an IH trip plow to pull behind my f-20. It has two 14" bottoms and steel wheels. Can anyone give me info on how to identify this plow?
BOB
06-06-1999 18:04:36
 Re: 2-14 plow in reply to Andy Glines, 06-05-1999 23:04:49
I ASSUME WHEN YOU SAY TRIP, THAT YOU MEAN YOU TRIP THE MECHANICAL LIFT TO RAISE THE PLOW FROM THE GROUND.(RATHER THAN ATRIP BEAM PLOW) THIS BEING TRUE I WOULD THINK IS MOST LIKLY A LITTLE GENIUS #8. THESE WERE BUILT FROM 1928 TO 1960. THIS PLOW HAD TWO LEVERS TO ADJUST THE PLOWING DEPTH AND LEVEL THE PLOW. IF IT USES CRANKS TO ADJUST THE DEPTH OR DOES NOT HAVE REAR FURROW WHEEL THEN IT COULD BE A LITTLE GENIUS # 12 OR LITTLE WONDER #1. GOOD TURNING
