Super M oil pan
goph
02-17-2002 13:06:26
Just purchased my 1st tractor and there are a few leaks. Is there much to dropping the oil pan and replacing the gasket? How about the valve cover. Remember....I am new at this, so use simple terms. haha Thanks
RPM
02-18-2002 06:57:18
 Re: Super M oil pan in reply to goph, 02-17-2002 13:06:26
No problem at all, very simple, unbolt all bolts and replace, will need new gasket, also check oil pan corners, we used to weld them all a lot, was a difficult steel stamping to make, you will see wrinkles in corners anyway.
Denny Frisk
02-18-2002 10:46:38
 Re: Re: Super M oil pan in reply to RPM, 02-18-2002 06:57:18
Your RIGHT! I think Dad's welded all 4 corners on His '51 M. Never had any problems with the H's... and he got rid of the Super M-TA and 450 while they were still too new. Dad bought the M new and it turned 50 day or two before Christmas.. The Super H was bought used, about 13 yrs old... Both still run good!
Denny Frisk
02-17-2002 16:04:15
If you haven't gotten them already You should get Operator's manuals, a parts book and a Service manual. Lots of repair & maintenance advice in the Operator's Manual. Exploded parts views in the parts book. And disassembly and reassembly directions, torque specs., and trouble-shooting proceedures in the service manual.
goph
02-17-2002 16:09:37
 Re: Re: Super M oil pan in reply to Denny Frisk, 02-17-2002 16:04:15
where are you able to get a service manual? Thanks
sammy the RED
02-17-2002 19:40:42
 Re: Re: Re: Super M oil pan in reply to goph, 02-17-2002 16:09:37
Get your manuals at your local Case/IH dealer or Binder B ooks.
sammy the RED
02-17-2002 13:09:49
Its a easy fix. Drop pan clean old gasket. Replace with new one, and use a little perm a gasket.
