Rear axle differential seals gaskets for 45 model B
Gordon in Tx.
03-17-2002 07:27:52
I am in the process of disassembling the rear end to replace all the seals & gaskets. I have a parts book & have all the parts numbers. Can these seals be cross referenced at a parts store like napa using the parts numbers from the IH parts book? or is there another way to go about finding these seals. I emailed Bermuda Ken 2 weeks ago with this question & have gotten no response. Must be on vacation...lol any help would be greatly appreciated. Thanks in advance
gene b
03-18-2002 04:40:39
 Re: Rear axle differential seals gaskets for 45 model B in reply to Gordon in Tx., 03-17-2002 07:27:52
450083# for the inner one and 45222 for the outer one these are CAR QUEST# around 53 for both sides these are the ones for left and right axle shafts
Gordon in Tx.
03-18-2002 06:20:36
 Re: Re: Rear axle differential seals gaskets for 45 model B in reply to gene b, 03-18-2002 04:40:39
Thanks gene. I guess I just need to pull all the seals & take em in. I am going to replace the axle shaft seals, the differential shaft seals, theinput spline shaft seal & all seals on pto & belt pulley. Is there anything you can think of I need to be aware of? Again thanks
Wayne
03-17-2002 22:57:50
I just reworked the rear end on my 49 "C". Got the seals from a local sorce also three bearings. I took the old seals and bearings into the shop and they came up with some good replacements. Everything fit. I had to redo the backlash because of the new bearings. Ken was unable to come up with the shims but he gave me a number(1-888-966-1066 Mike) who had some shims. I'm using blue RTV for gaskets.
