Super C lift capability
Gordon Mosher
04-08-2002 11:35:22
Last week when I asked all told me that a 1200lb disk was too heavy for my Super to lift. Well you were mostly right, it would lift it, but made it real light on the front. The tractor has a homemade 3-point that was on it when I got it. It does use a cylinder, but because of the lift arm length I couldn't get the disk high enough to load on a trailer. I will admit that I need to put the dual wheel front with weights on the tractor instead of the single, if I intend to try that again.
supercmore
04-08-2002 21:20:25
 Re: Super C lift capability in reply to Gordon Mosher, 04-08-2002 11:35:22
I have a Super C with front wheel weights. It handles a 7 1/2 foot fast-hitch disc just fine. In 2 gear everywhere, 3d in some places. Just be careful when you get to end or row and lift disc...use your brakes to turn, 'cause front end IS coming up!! Cmore
Big John
04-08-2002 18:50:55
You only gave the weight of the disk so I really don't know how big it is or what type it is. But before you go much farther with this, I would give it a try to see if you can pull it with your Super C. It may be that not only is it over doing the lift and weight balance, it also may be to much disk for the Super C to pull.
Give it a try and then you will know for sure if you want to go a head with this.
