TA additives????
560man
04-08-2002 17:51:18
I was reading something the other day and saw something about adding an additive to the transmissions on TA equipped tractors. Well so happens to be I have two of them out in the barn. What oil should I be using and is there an additive I should add???? Thanks.
RPM
04-09-2002 06:29:07
 Re: TA additives???? in reply to 560man, 04-08-2002 17:51:18
IH listed a additive for TA in early days, no longer required with current Hytran.
sammy the RED
04-08-2002 23:18:59
It should work just fine with Case/IH Hy-Tran in it. No need for a additive.
Dan
04-08-2002 21:09:03
folks here have suggested using Hy Tran or equivelent in tractors with a TA. Don't know about additive. I wouldn't think you would need it if using Hy Tran.
