TD 14?
Gordon-(TN)
04-29-2002 23:27:31
I'am looking at a td 14 I need to do some cleaning about the place and this one is close to me. can someone give me the good & bad on this dozer. thanks for your help Gordon-(TN)
RPM
05-04-2002 07:15:26
 Re: TD 14? in reply to Gordon-(TN), 04-29-2002 23:27:31
You must remember this crawler is at least 50 years old, made in the 1940 first, they were as good as anybodys, their best feature was easy starting compared to Cat of that vintage with tempermental pony engine.
right said fred
04-30-2002 19:24:41
Except for the cylinder heads cracking if the coolant level got too low, the td 14 is a good dozer for its size. Over time, many had their fuel pumps turned up to get more power, and you could see some gear problems. If it is kept full of coolant and oil everywhere, you should just see normal wear of tracks, rollers, etc.
