Super M backfiring
Jim F
05-12-2002 10:14:31
When I shut down my tractor after use (nothing hard) it will occassionally backfire... Is there something I could do, or leave it alone.. Thanks
gene b
05-13-2002 02:17:10
 Re: super M backfiring in reply to Jim F, 05-12-2002 10:14:31
sound like the plugs need cleaning or changed this problem is not uncommon when just messing around needs a good couple of hrs work on a pull
Jim F
05-12-2002 13:01:08
Thanks for the info guys!
Bob M
05-12-2002 12:57:53
Mine does on occasion too. Usually just a little "woof" out the exhaust, but once in a while it's like a shotgun blast. Like Craig says it's unburned fuel lighting off in the hot exhaust manifold as the motor rolls to a stop. I wouldn't worry about it...
Craig MO
05-12-2002 12:45:15
Ours will do that if you shut it off too soon let it idlde for a minute and it should not backfire. Its a little unburned fuel in the manifold after the ignition is turned off and the engine still turned over. It won't hurt a thing.
