Cost for Rod Bearings
GrampsOld544
06-10-2002 09:22:55
Well I broke down and called a guy to look at replacing the bearing on my I-544. What should I expect to pay to have the rod bearing replaced?
RPM
06-12-2002 06:24:57
 Re: Cost for Rod Bearings in reply to GrampsOld544, 06-10-2002 09:22:55
I am a little vague on your question, are you asking price of parts or labor or both ? Pan gasket is $15, rod bearing is $12, labor is depending on travel, flat rate in shop is 1.8 hours, if rod bearing failed without damage to crank journal it would be a suprise.
