Old int tractor-grader
bill
06-16-2002 16:37:40
Hi, i ran onto a very old looking tractor that has a road grader attached... it has no seat you stood on the back with just a clutch pedal there.
it is in bad shape the guy said had a stuck vavle and clutch,the gas tank has old gas that has turned to laquer. body and metal ok. it has old wheels with rubber tires.. the only number i could find was on thre rearend 1523db,,,the guy said he has $600. in it. he told me to make him an offer,it is about 40 mintues from my home.. any help would be much app.. thanks.
RPM
06-17-2002 11:31:29
 Re: old int tractor-grader in reply to bill, 06-16-2002 16:37:40
I have seen rare pictures of this, IH sold the tractor with options, cant remember much else about it, number you furnished goes back into F20 and before by series, there was a fellow I believe on another forum that had one with M tractor, rear wheel hubs were splined on axles and loose.
jal-SD
06-17-2002 06:30:28
I have seen this type of grader w/both M's & F-20's under them. M's were a lot more common in our part of the world. (I've also seen them w/AC's under them.) Small town that I grew up in had an F-20 which ran well that they sold on a surplus sale in about 1963 or 64. No one wanted it because it was a crank start, but started on the third pull. Iron buyer (sob-sob) got it. (My $0.02 worth. jal-SD)
bill
06-17-2002 13:51:49
 Re: Re: old int tractor-grader in reply to jal-SD, 06-17-2002 06:30:28
hi, i talked to a construction guy today and he said he ran a int tractor with a broom on it that he stood behind years ago..
the guy that owns this tractor said he wanted his $600. back or might sell as salvage.. i have been trying to decide whether to make him an offer an how much.. thanks to you guys,,,,
Alton
06-16-2002 20:18:03
They made a M Framall with a Trojan grader attachment to the front.
bill
06-17-2002 04:18:25
 Re: Re: old int tractor-grader in reply to Alton, 06-16-2002 20:18:03
this tractor just has a place to stand behind the rear axle and drive it, the blade hooks under the belly and was believed to be a state road tractor.
i have looked at all pics i can find on the antique tractor sites and see nothing close...thanks
Sspiritpower
08-13-2004 15:58:54
 Re: Re: Re: old int tractor-grader in reply to bill, 06-17-2002 04:18:25
I have a 1943 model M farmall MFBK 61692 WITH A Trojan utilty speed patrol grader with a 12ft blade and a cap with a seat that I believe was a attachment all HYD. Want to sell make a great piece
howard
06-16-2002 18:09:12
I was thinking that maybe it is a 10-20 tractor built into a grader. is there a name on the grader? try and find some more casting numbers. I could not find the one you gave.
