Order Farmall Cub Parts Online
'51 cub update
Mark Kw
06-21-2002 04:32:35
I asked a few days ago about a 1951 farmall cub with a cracked axle housing. Owner decided to chance making the weld repair without disassembling the axle and wheel gears. Took my time, grooved the crack out after removing the previous weld metal from the prior repair. Used a combination of nickle and non-nickle cast iron electrodes. Pre-heat to 450F and post heat for 2 hours at 400F before starting a two hour slow cool down. Repair looks good and seems to be holding well. Thanks for all the help, just wanted to let you know it's much appreciated.
Peter Woodward
10-25-2003 05:09:57
 Re: '51 cub update in reply to Mark Kw, 06-21-2002 04:32:35
Would like to make contact with anybody about the 1952 super C Farmall tractor I have just purchased,the best way to to keep runing smooth and restoring it back slowly to it's original condition.
peter woodward
10-25-2003 04:57:26
Have recently purchased a 1952 farmall tractor and would like to speak to anybody out there of the best way to restore it and keep it in good condition and still be able to use it on a daily basis.
redrev
06-21-2002 07:16:26
Good job. My friends won't even let me near a welding rig, which is good for me and for anything I might be attempting to weld. Difficult welds are a real art.
