Darn carb problem in I-544 gas
Grampsold544
06-24-2002 09:09:57
I have a I-544 gas engin and it starts and runs fine for about 15 minutes then stalls. The only way it will restart is if I spray starting fluid into the carb. Then it will fire right up and idle. When I put it in gear it runs for about 4 feet and stalls out. Then this process needs repeated.
My question is what is wronge with my Carb? Not enough gas when the engin warms up is my guess. Before I drop $300 in a new carb, what adjustments can I make to try to correct this problem. I have already had the carb appart and everthing looks fine. P.S. My floats are not sticking (I have already had someone look at that). I have a Zentith carb with a blead screw instead of a solnoid shut off.
One more piece of info, the fuel pump has been removed and converted to a gravity feed. I can see why it might stall under this situation, but why does it refuse to restart?
Bruce (WA)
06-27-2002 23:19:10
 Re: Darn carb problem in I-544 gas in reply to Grampsold544, 06-24-2002 09:09:57
fuel pmup went bad on my 544 and it would run fine on gravity as long as the tank was at least 3/8 full . otherwise it would run a little while and die. put a new pumpon and also blew out the carb. htere was some crud in the passage between the inlet screen and the float valve.
Grampsold544
06-28-2002 05:05:31
 Re: Re: Darn carb problem in I-544 gas in reply to Bruce (WA), 06-27-2002 23:19:10
I put my new fuel pump on and it ran. I took a victor lap around my house (wife was a little pissed). I think the pump solved my problem. My engin still want to ramp up a little and it 5 gear I was shooting some fire out my exaust. Is that normal?
Old Dutch
06-24-2002 16:36:01
Just curious, but does that tractor have the rear mounted fuel tank? If so, replace the fuel pump and that should solve the problem.
Gramps
06-25-2002 05:03:47
 Re: Re: Darn carb problem in I-544 gas in reply to Old Dutch, 06-24-2002 16:36:01
I am replacing the fuel pump this week. Hopefully this will fix the problem.
