I-544, jumps when I put it gear.
Grampsold544
06-28-2002 05:15:21
I have a I-544 gas with a gear drive and T/A. With the clutch in as I change gears, the trator will jump slightly as I place the tractor in gear (Clutch remains in). This does not happon evertime. Is this normal with a gear drive. After the slight jump it remains still till I release the clutch.
Ace Schrunk
06-29-2002 10:22:49
 Re: I-544, jumps when I put it gear. in reply to Grampsold544, 06-28-2002 05:15:21
No if you don't have manual email me. I wiil talk you through
Grampsold544
06-28-2002 08:29:51
Is it a lot of work to adjust the clutch?
Hugh MacKay
06-28-2002 19:48:54
 Re: Re: I-544, jumps when I put it gear. in reply to Grampsold544, 06-28-2002 08:29:51
Who ever said owning a tractor was easy. Better to adjust clutch than pay the repair bills.
Ace Schrunk
06-28-2002 08:12:45
That is not normal With the clutch held out put it in gear move a little then take it out of gear but still hold the clutch out and wait a little and put back in gear and see if gears grind if the do you will have to adlust clutch or clutch could be haning up. Once gears have been stool turnning they should stay stoped.
Grampsold544
07-01-2002 08:54:39
 Re: Re: I-544, jumps when I put it gear. in reply to Ace Schrunk, 06-28-2002 08:12:45
Looks like I will have read my service book to see what is involved. Thanks for the input.
