Hi Jeff, I'll try and answer your questions. 1. The big centet knob, on top of the carburator, is the load adjustment. It is the notched knob, with a wire keeper. The small screw is for idle adj. 2. I'm not sure of this, but probably not. You should be able to get one for a Regular or F-20. 3. Most gaskets are available, and I'll leave some info, at the end. 4. 110-115 ft. lbs. 5. Yes, removing these "hand holes", will allow you to inspect the crankcase. 6. This would be an aftermarket item. 7. Yes, you can get them on this site, and through other venders. Companies, that offer Regular parts are, Rice Equipment Co. E. Main St. Box 267 Clarion, PA 16214 814-226-9200 Kinsinger Service R.D.1 Meyersdale, PA 15552 Webers Tractor Works www.webertractorworks.com There probably other fine companies also, that I have ommitted. I hope this helps. Happy Tractoring, Ken
