Order Farmall Cub Parts Online
'49 Cub wiring diagram
Jimmy Burcher
07-02-2002 08:39:52
I have a student who just completed the overhaul of his grandfather's '49 Cub in our school shop. Some of the wiring had been switched over the years and we are having a hard time helping him correct wiring problems. Local IH dealer was able to provide the generic diagrams from their manuals, but their diagrams show a 3-lug regulator mounted on the top of the magneto. This tractor has a 3 lug cutout relay (I think) on top of the generator. All wiring is original 6 volt and we hope to keep it that way. Light switch is a 4 position switch. Would anyone have a copy of a schematic wiring diagram that you can help us out with? So far the archives haven't been of much help on this model.
Thanks
The Red
07-02-2002 10:23:03
 Re: '49 Cub wiring diagram in reply to Jimmy Burcher, 07-02-2002 08:39:52
Punch below, this should be close to what you need. If you have a mag, disregard the portion of the wire going from the negative side of the ampmeter to the coil switch and then the coil.
Eric Francis
04-19-2005 10:08:13
 Re: Re: '49 Cub wiring diagram in reply to The Red, 07-02-2002 10:23:03
need wiring diagram for a 49'c farmall
can you help me
Alvin Hendrickson
09-10-2005 16:55:16
 Re: Re: '49 Cub wiring diagram in reply to Eric Francis, 04-19-2005 10:08:13
My Cub has a magneto, but the regulator is mounted on the generator. Help Please.
Jimmy Burcher
07-02-2002 10:54:35
Many thanks for the fast assistance. I should have mentioned that the Cub has a J-4 magneto. Your wiring diagram link was teriffic. I did print out a copy of both the distributor igntion schematic and the magneto ignition schematic. This looks like it will help us finish this project.
Jimmy Burcher
The Red
07-02-2002 10:57:29
 Re: Re: Re: '49 Cub wiring diagram in reply to Jimmy Burcher, 07-02-2002 10:54:35
If you hit a snag, email me and I'll walk you through it. My Hs and Ms all have the VR on the generator and the 4 position switch.
Alvin Hendrickson
09-10-2005 17:12:51
 Re: Re: Re: Re: '49 Cub wiring diagram in reply to The Red, 07-02-2002 10:57:29
I have a 1949 F-cub with a magneto. It has the voltage regulator on the generator. It does not have lights. I believe that the wire from the start/run pull switch should go to the screw on the side of the magneto. Is this right? The regulator has an "L" terminal, a Gen. terminal,and an "F" terminal. What do these conect to? The dash has a push pull switch, a terminalblock, an ammeter and a rotory switch. Help. Help. Please.
