Wiring diagram
ken flannery
07-04-2002 16:13:31
If anyone can help me I would appreciate it. Need a wiring diagram for a 49 cub. The pictures in owners manual are not real clear. It is 6v with a 6v coil. I need to know where the wire from amp. meter goes. One goes to reg. and the other says it goes to the battery. Can it be hooked to starter? Also it has a four position light switch and that does not appear to be wired right. The fella that owns it cut the wires and put on a new generator and regulator when he put in a new clutch. I am trying to help him get it back together(right) I do know about polorizing the gen. because it is pos ground. Thanks alot to anyone who can help.
Doug in OR
07-04-2002 17:05:59
 Re: wiring diagram in reply to ken flannery, 07-04-2002 16:13:31
One side of the ammeter will go to the battery, and the other side will go to *all* other connections, including the regulator "bat" terminal. If the meter reads discharge when you know it is charging, or reads charge, when you know it is discharging - you will need to reverse all the connections on the ammeter. I hope this helps.
jim
07-05-2002 10:01:20
 Re: Re: wiring diagram in reply to Doug in OR, 07-04-2002 17:05:59
Doug in OR. Hey Doug, Check the achives on YESTERDAYS tRACTOR WEB PAGE.Look under electrical schmatic. You should find wiring diagrams that would help. Good Luck
Elmer Wolf
10-13-2004 11:26:26
 Re: Re: Re: wiring diagram in reply to jim, 07-05-2002 10:01:20
Do you have a wiring diagram for a Farmall International H?
