F20 carb settings
Mark B
07-30-2002 19:04:34
I have a F20 with a Zenith carb and wondered the correct settings for this. It seemed like it was getting alot of black smoke out the exhaust.I tried messing with it(not knowing what I was doing) and now you shut the fuel off to shut it off and getting fire out the exhaust before it dies. Any clues? Thanks, Mark
George Mikesell
09-11-2004 20:22:33
 Re: F20 carb settings in reply to Mark B, 07-30-2002 19:04:34
The setting is 1and 41/64, with flaot on base and turned upside down. Is your idle jet circuit clean? It almost sounds like you are trying to idle off the load circuit instead of idle circuit. Yet you must be sure that it is not flooding over first. Which in this instance sounds like your problem
Justin Loehemer
10-06-2004 17:50:00
 Re: F20 carb settings in reply to George Mikesell, 09-11-2004 20:22:33
Hey iam having alot of trouble getting my f-20 started it worked but i had to cleen it out because one of the ports were cloged so when i was done it ran perfec then a week later it wouldent run its like its not getting any gas can anyone help me
Dave
07-31-2002 04:16:55
check to see if you have the plug wires correct. Possible that the middle two are switched.
