Leaky carb fitting
Gramps544
08-08-2002 09:23:42
The treads on my main fuel jet assembly are stripped going into my carb (544 tractor gas). Now the whole brass assembly is loose and leaks gas. What can I use to seal this up??
I was thinking about using epoxy gas tank repair materail. I know this will make it hard to remove this fitting, but I do not know what else to use. Any help would be greatly appreschated,
justin
08-09-2002 19:31:05
 Re: Leaky carb fitting in reply to Gramps544, 08-08-2002 09:23:42
Gramps, If all else fails and you can't re-thread it use JB Weld ( it's a 2 part epoxy) Good luck I swear by that stuff
RPM
08-09-2002 06:16:17
3 different carb styles on 544, 2 had screen/elbow fittings that were pipe threads, 1 on hydrostatic drive was straight threads on brass fitting that had a sealing fibre washer.
Gramps
08-13-2002 13:55:02
 Re: Re: Leaky carb fitting in reply to RPM, 08-09-2002 06:16:17
I have a stright thread brass fitting. Mine is a gear drive.
I have read that you can use JB weld with silcone on the treads to repair the stripped treads. I will give it a try. Thanks for the responses.
