Thanks Bob M
Gordon (Tx)
08-10-2002 17:07:43
Bob I hooked up the key switch ignition today. Works just like it is supose to. Installed a new ammeter while I was at it. M was already converted to 12 volt when I got it. The ammeter shows a little over 30 amps when running. The battery was pretty low when when I first started it. Is this a normal reading, for an alternator? Once again thanks for the diagram & your help. Gordon
Bob M
08-11-2002 07:18:05
 Re: Thanks Bob M in reply to Gordon (Tx), 08-10-2002 17:07:43
Thanks for the kind words Gordon!
30 amps charge into a low battery is normal with an alternator. It may do this for 2 - 3 hours of running before the battery comes up all the way. However when the battery is full the ammeter should show only 2 - 4 amps of charge at governed RPM. Any higher than this will overcharge and eventually ruin the battery.
If you have an accurate DC voltmeter, take a reading directly across the battery with the motor running at at governed speed. If meter reads less then 14.5 volts or so, everything is fine. If it shows >15 volts, you are overcharging.
Gordon
08-11-2002 10:57:49
 Re: Re: Thanks Bob M in reply to Bob M , 08-11-2002 07:18:05
Bob I checked across the batt. with my voltmeter, it was reading 14.3 volts at governed speed. I've had the old girl running most of the morning & the amp. gauge has backed off to a little less than 15 amps. So again thank you for the help. It's plenty HOT here in central Texas, hope September hurry's up & gets here..... Gordon
The Red
08-11-2002 07:04:42
Gordon that is high if your battery is fully charged. Keep an eye on the water level in the cells!! With a full charged battery, you shouldn't see a reading over 15 amps.
Gordon
08-11-2002 11:01:05
 Re: Re: Thanks Bob M in reply to The Red, 08-11-2002 07:04:42
Thanks for the help Red, I think it's working like it's supose to, but I'll take your advice & keep an eye on the cells. Better safe than buying a new battery. I'd offer to send ya some of this heat, but sounds like it's just as warm in Ind. as here. Again thanks for the help....Gordon
The Red
08-11-2002 11:33:57
 Re: Re: Re: Thanks Bob M in reply to Gordon, 08-11-2002 11:01:05
Gordon for central Indiana, we have had a hot and very dry summer. If we don't get rain within a week, my soybeans are going to be a bust this year. Last year they yielded 60 bpa!
Gordon
08-11-2002 12:38:00
 Re: Re: Re: Re: Thanks Bob M in reply to The Red, 08-11-2002 11:33:57
I know exactly what you mean Red. Spring was dry here most hay patches were only rolling around a bale an acre. We were fortunate enough to get several inches of rain last month & the hay is doing much better at 3 to 4 rolls per acre now. Can't make money at a roll an acre. But the grass is burning up in a hurry now.
