Wide front spindle question
David
08-25-2002 19:35:16
I recently picked up a wide front to fit my Farmall M. Only problem is the right spindle is missing. The top of the spindle is splined, instead of being keyed into the tie rod end. Does this sound familiar to anyone? I can't find any identifying marks on it anywhere, so I'm not sure where to find a spindle. Any help will be appreciated.
mike zahn
10-25-2003 19:36:43
 Re: Wide front spindle question in reply to David, 08-25-2002 19:35:16
I would like to purchase the other spindle if it is for sale.
RPM
08-26-2002 06:11:15
WFA are not hard to identify, most common is IH, 2nd is Schwartz-A&I, also Norden-Russell, and Speeco, if it is made of cast iron for the main bolster under the radiator its a IH, could be late model with latest spindles, big nut on top, Schwartz is splined with clamp bolt in arm, if you take the other side off it will have a number stamped in bearing shaft to identify Schwartz.
