BobM...electrical help please
DaveJ(WI)
08-28-2002 15:29:55
Do you still have the schematic showing how to eliminate the toggle/momentary on switch on a 10si conversion on a mag equipt Farmall? This would be a big help .Please and thank you.
DaveJ(WI)
08-28-2002 19:54:54
 Re: BobM...electrical help please in reply to DaveJ(WI), 08-28-2002 15:29:55
Thank you. The double throw setup is the one I'll use.
Bob M
08-28-2002 17:16:36
Dave - Simplest solution is to replace the existing button ignition switch with a DPDT toggle switch, as shown in diagram #7 in the link below. Another way is to use a single wire 10SI alternator (diagram #9), However single wire alternators are more expensive, and have some functional drawbacks over their 3-wire cousins.
You could also add a relay and swap the existing N.C. ignition switch with an N.O. switch, but you then add complexity (and cost). My advice is to keep it simple and use a toggle switch!
Barry
07-01-2003 21:23:13
 Re: Re: BobM...electrical help please in reply to Bob M, 08-28-2002 17:16:36
BobM,
I have recently been working on a 47 Farmall M with a 12v (3-wire Delco) conversion and was wondering what the difference was between a 12v cutout and the 3-wire alternator hookup such as you've posted previously in this forum.
The cutout on the M has 4 contacts: 2 to the alternator (F/S), one to the keyed ignition and the remaining contact is unused. I'd first attempted to use the cutout and had no sucess as the tractor had been sitting for a few years and the contacts, etc. were corroded. After getting no response out of the alternator using the cutout, I hooked up the alternator per one of your diagrams (3-wire) and the ammeter jumped to steady 20A charge until I disconnected the sense wire. Will the alternator ever stop charging using your setup? Meaning, is there a voltage regulator internal to the alternator or a cutout? Thanks for the help.
Barry
