Electric F 20
Curt
09-09-2002 14:33:21
I want to get a f 20. it has electric start but the starter is gone. what will fit this thing as a replacement. i am not a big fan of hand cranking so i would like to fix the eletctric components.
George Mikesell
09-07-2004 13:11:56
 Re: Electric F 20 in reply to Curt, 09-09-2002 14:33:21
Starter for F-20 was originally a Delco Remy. I don't have the original no off hand but my neighbor has one that I sold him and can get it for you. The starter was like MM U tractors except turned opposide direction. Most long nose starters of the 40's and 50's will work provided turn correct direction. I have also mounted Chrysler reduction starters throuch rear of bell housing, requires quite bit of work and machining. Let me know if you want no, I believe that you can go through specialty rebuilders and get the starter, once you know no.
