Farmall m duals
mark
09-10-2002 13:21:19
does anyone have a photo of an m with duals. can you use 2 of the cast wheels with one facing inward and one outward with the rims on as duals or is the axle not long enough or strong enough
joe
09-10-2002 19:24:59
 Re: farmall m duals in reply to mark, 09-10-2002 13:21:19
I have thought about doing this to our 400, and as far as i can tell, you could do it. You would have to have the inside wheels slid all the way in, and butt the hubs right up next to each other, and then you'd have about and inch or two to spare on the axle. And you'd have three or four inches between tires.
Dave
09-10-2002 19:24:07
Yes Mark my Dad has run a set of M cast wheels as duals on one of His SMTA's since the early
1960's. You are correct, the inside wheel must
be dished in and the outer dished out.I should
also mention He runs 15.5-38,s all the way across.
good luck Dave
gy3020
09-10-2002 17:27:05
I have a picture of one with duals on it, send me your email and I'll be glad to email it too you.
Jack in Fla
09-10-2002 15:58:49
Mark here is a SMD with 14.9 on rear and 670.16 on front, is a sharp machine that is at Florida Flywheelers Asoc. in Avan Park Fla. Will have to put pic in Tractor photos because I do not know how to put it here Jack in Fla
ff316
09-10-2002 20:27:39
 Re: Re: farmall m duals in reply to Jack in Fla, 09-10-2002 15:58:49
third party image
Here ya go. That is a SHARP ride! Take care, Fireman
MARK
09-11-2002 09:54:12
 Re: Re: Re: farmall m duals in reply to ff316, 09-10-2002 20:27:39
THAT M REALLY LOOKS TOUGH. YOU HAVE INSPIRED ME TO DO THE SAME ON MY 1951 M. THANKS FOR THE PICTURE
Jack In Fla
09-11-2002 16:33:32
 Re: Re: Re: Re: farmall m duals in reply to MARK, 09-11-2002 09:54:12
That was not my SMD, belongs to a friend.It runs as good as it looks too. I have a 53 SM that I am going to do the same thing to but I am going to leave it in its work clothes with new decals. Belive it will be sharp that way Jack
ff316
09-11-2002 10:38:04
Don't give me the credit. It's Jack's picture, I just moved it here from the photo archives. It is pretty mean looking, isn't it? Fireman
The Red
09-10-2002 14:25:24
Mark the hub thicknes is roughly 7". There is only enough room to point both hubs towards or away from the transmission. Axle length from the housing out is roughly 16".
