Anyone ever ran a Behlem 500 batch drier with a Super M
andy
09-10-2002 21:05:05
Just wondered if a Super M Farmall is powerfull enough to run the fan on a Behlem 500 bushel batch drier? I hooked it up one day a couple of years ago and it seemed to get tired after a while. I didn't have corn in the dryer. A neighbor told me yesterday that an empty drier will pull harder than a full drier. Something about the static pressure in the drier when it is full of corn. Any ideas on these two questions? Thanks
Larry See
07-12-2005 18:09:16
 Re: Anyone ever ran a Behlem 500 batch drier with in reply to andy, 09-10-2002 21:05:05
How do I hook up the proportioning valve on a Behlem power steering system? Help!
another doug
09-11-2002 17:11:37
 Re: Anyone ever ran a Behlem 500 batch drier with a Super M in reply to andy, 09-10-2002 21:05:05
Andy , we use a 4020 John Deere diesel, tried a Super MTA at first , but switched over and I can't remember why ,guess it wasn't enough horsepower, but if a guy would stay at the dryer (hard to do for me) You could keep an eye on it if anything goes haywire,what are your intentions? got any other tractors?
Ron (I used a MD)
09-12-2002 06:32:59
 Re: Re: Anyone ever ran a Behlem 500 batch drier with a Super M in reply to another doug, 09-11-2002 17:11:37
I use a MD and didn't have any trouble. But I remember Dad's M gas would not pull the drier with out getting hot.
andy
09-11-2002 21:09:48
I have a Case 2290 but hate to put it on the dryer. The operators manual for the dryer says any 3 to 4 bottom plow tractor should work. The owner of the dryer before me used a John Deere 4320. I think the fan blades are cranked to a pretty steep pitch. I tried the super M once when the dryer was empty. Seem to run it ok for a while and then got hot and didn't want to run right. A neighbor told me that an empty dryer pulls harder than a filled dryer. I should try the dryer with the "M" when it is full. I will probably run it with a IH 706 which I am overhauling now. Thanks
