Super C
john
09-19-2002 09:27:32
Have located a Super C. There is 1/2 slop in the steering wheel. None of it seems to come from the universal joints. What is going on here, what is the fix, and what is the cost? Thanks in advance for any and all help.
Haas another comment
09-19-2002 18:23:36
 Re: Super C in reply to john, 09-19-2002 09:27:32
I assumed you are talking about 1/2 turn of play. If you are talking about 1/2 inch, forget about it.
Haas
09-19-2002 18:21:19
Just finished reworking my second C steering gear. First place to look is the worm gear behind the big plug on the front of the steering box. Drive the pin out where the universal joint is connected to the worm gear, take loose the mid steering shaft bearing on the side of the clutch housing and pull the universal joint off the worm shaft. Remove the woodruff key from the shaft. Then drain the oil out of the steering box and take out the big plug in the front. Screw out the worm gear and shaft. The ball bearing on the end of the worm shaft must be tight with no play. It must be held tightly against the shoulder on the worm shaft by the castle nut which is retained by a cotter pin. And finally when installed in the box, the outer race of the worm shaft bearing must be clamped in tightly by the big plug. Any looseness in this bearing or the clamping system results in steering play. Next, jack up the front of the tractor and support it on the flat spot at the clutch housing. I recommend using 6x6 cribbing. Then see if you can wobble the front wheels(I'm assuming you have a tricycle front) side to side or front to back. If you can, then one of the main support bearings is bad and you will have to drop the main steering shaft and worm wheel out the bottom to replace the bad bearings. In the two I've done, those bearing were OK though. I doubt that wear on the worm gear or the worm wheel is causing 1/2 turn of play. It's likely the worm shaft bearing or the main support bearings. The ones I did had about 1/4 turn when I started. When done, both were less than 2 inches and one is only about an inch. If you drop the gears out the bottom, advisable to replace the oil seal on the bottom while you are into it. Also when you are doing this, you can turn the worm wheel 180 degrees on the spines so that the worm gear is wearing on a new spot.
Paul shuler
09-19-2002 14:58:57
On my Super I took the big plug off on the front bolster that allows you access to the worm gear, I just turned the big castle nut about a 1/2 turn and that will take out a lot of the play and it's easy. If a 1/2 inch is all the slop you have in it that's not to bad for a 50 year old tractor.
Ken Cunningham
08-19-2004 09:41:00
 Re: Re: Super C in reply to Paul shuler, 09-19-2002 14:58:57
I can"t get the "big plug" out of the front Bolster.
Any Ideas? I"m starting to strip it. Does it come out by turning it counter clock-wise? I"ve got to replace the bearings and clips. The stearing shaft keeps backing out. Nothing is holding it in place. I also need someplace to buy these parts once I get it out. Thanks to anyone who can help me!!
