Broken oil indicator valve
GooseCreek Farm
10-03-2002 05:56:47
I have a Super C with a broken oil level indicator valve on the side of the oil pan. Can these be replaced without taking off the oil pan? Are they threaded and will they just turn out? I would appreciate your help.
randy hall
10-03-2002 12:24:32
 Re: Broken oil indicator valve in reply to GooseCreek Farms, 10-03-2002 05:56:47
yes they are supposed to screw out with a pipe wrench, they are 3/8's" pipe thread.
Don LC
10-03-2002 09:30:30
Turn it out with a pipe wrench..... use plastic thread tape on the new one,be careful not to "crush" it with the pipe wrench.....I bought mine at a tractor show for $10..... ..
JONATHAN MIRGON
10-03-2002 07:43:25
I HAVE AN (A) AND I REPLACED BOTH OF THEM ON MINE. IM PRETTY SURE THEY USE THE SAME OIL PAN. THEY ARE THREADED IN FROM THE OUTSIDE, SO YOU SHOULD NOT HAVE TO TAKE OFF THE PAN, SOAK IT DOWN WITH PENETRATING OIL FIRST. IT TOOK A 12" PIPE WRENCH TO GET MINE OUT.
GOOD LUCK
Slappy
10-03-2002 06:54:03
I'm not sure about the Super C, but when I replaced one on my H it was turned in so tight that I needed a pipe wrench to screw it out.
Dave_Id
10-03-2002 06:47:18
I believe so, Had a C with just threaded pipe plugs, so it must have pipe threads
