Changing gears makes my teeth hurt
Gramps514
10-08-2002 09:52:17
I finially got my International 544 running gear drive with TA (8 forward/2 reverse gears) When I first push in the clutch and select a gear, a horrible sound is made as the gear teeth try to line up. It will go into gear after about 2 sec. After it is engaged and running, I can push in the clutch and shift gears without grinding. If however I put the tractor in neutral and then try back into a gear, i have the same grinding sound again.
Does this sound like a clutch adjustment problem or a replace the clutch problem? I can use the tractor as is, as long as I never leave it out of gear (or it will grind). Due to me having get of the tractor periodically this is becoming nolonger an option. I could really use insite on this problem.
RPM
10-10-2002 10:52:06
 Re: Changing gears makes my teeth hurt in reply to Gramps514, 10-08-2002 09:52:17
This tractor was not made to shift on the run, I was around them new at dealer (I unloaded them off truck), You might check adjustments anyway, should be in op manual, TA will shift anytime.
Bryce Andreasen
10-09-2002 08:31:43
Same way with my H, i thing it is just that every thing in the transmission is still settling down or slowing down from going engine speed. I also had to cut my clutch rod off about a foot off from the end with the threads. I welded a bodt anbout 11 inches long onto it so i can push it in further. But first, try putting the clutch in and wait two seconds then put it in gear.
Steven@nd
10-08-2002 11:18:53
Check your free pedal on the clutch, it is not releasing completely.
Gramps544
10-08-2002 12:37:03
 Re: Re: Changing gears makes my teeth hurt in reply to Steven@nd, 10-08-2002 11:18:53
THere is not free travel at the top of my clutch (I think). Is there any purging of the air in the system needed? I know a automoblies hydraulic clutch needs to be bleed (air purged)
Steven@nd
10-08-2002 15:57:40
 Re: Re: Re: Changing gears makes my teeth hurt in reply to Gramps544, 10-08-2002 12:37:03
Our 544 just has a rod from the clutch to the pivot shaft that runs through the torque tube. If you have the utility, I don't know what could be different.
If there is no free pedal and it still doesn't completely release you are looking at a new clutch and/or pressure plate.
Steven
Anthony
10-08-2002 20:25:03
 Re: Re: Re: Re: Changing gears makes my teeth hurt in reply to Steven@nd, 10-08-2002 15:57:40
You might want to check your throught-out bearing. I've had the same problem on a Super A. Bearing was wore and let input shaft drop, which let the front top and rear bottom of clutch disk drag.
jmyt_47
10-08-2002 10:59:50
You need to adjust your clutch. I had the same problem on my 300.
