Girls B Farmall
Preston
01-07-2003 17:00:26
We have a team of girls from the Cumberland FFA competing in the tractor restoration contest. They are restoring a Farmall B, and have got it tore down to many pieces. Like all tractors so far, it is missing the serial number plates. They have located these numbers on the block: 114049. If someone could give us information using these numbers, we would greatly appreciate it. Thanks!
Ryan Free
01-08-2003 14:39:58
 Re: Girls B Farmall in reply to Preston, 01-07-2003 17:00:26
A friend of mine was in the FFA Tractor Restoration contest, it was like 4 years ago when he (Jared Bryan) won it with his Oliver 88, we are both members of the South Adams FFA. Good look on your B Farmall, would like to see someone with a RED one win it!
Al
01-08-2003 08:30:08
I don't have a reference with me but the first A's and B's had engine and chassis serial numbers that match. I THINK this B would be early enough to match, so that would tell you the tractor (chassis) serial number. Beyond that, you can come close to an age by using the casting numbers on engine block, trans. case, and other major cast parts. That is the date that particular part was made. They will be in a MM DD YY form, with the year represented by a letter.
1947-Q
1946-P
1945-O
1944-N
1943-M
1942-L
1941-K
1940-J
1939-I
So for example January 8, 1939 would be 1 8 I. Check several in case something was replaced over time, be aware that sometimes you can have factory original parts that vary widely in age, and sometimes everything is cast just a few days apart.
If the tractor is too new for serial number of chassis and engine to match, your best bet is to estimate with the casting codes. Generally the engine serial number will be much higher (newer) than the actual chassis number. There were sometimes some suffix and prefix codes on the enine number to indicate fuel burned, but that's hit and miss, some have them and some don't and it won't tell you much about its age anyway. If you can get a hold of Guy Fay's IH Tractor Data Book it breaks all this down in a very user-friendly format.
HTH, I would like to try the FFA Tractor Rest. contest with our chapter, how has it been so far for you?
Al
Bill Smith
01-07-2003 17:37:25
According to the serial numbers listed under research and info on this site it is a 1945 model.
Bill Smith
01-07-2003 19:46:49
 Re: Re: Girls B Farmall in reply to Bill Smith, 01-07-2003 17:37:25
Just wanted to add... Farmall had a common practice of stamping serial numbers not only on plate but on block and sometimes frame as well. The serial number on the plate more than likely had prefix and suffix letters example FA114049LFX. I am not sure if these letters were stamped in block and frame (maybe just the number). It is my understanding that the number itself is just the serial number and is really only useful as to determine the year or to identify in a theft incident. The letters however (if they are stamped with number in block) can tell you other things about the model. I think the prefix letters FA stand for Farmall. I think the suffix letters can tell you wheather it was a gas, distillate or kerosene burner and things of that nature.
Bob Gilliland
09-08-2003 10:54:36
 Re: Re: Re: Girls B Farmall in reply to Bill Smith, 01-07-2003 19:46:49
Good luck girls on your tractor. Unfortunately I have already restored the same model, and look forward to one of us taking home the gold.
