Temperature Gauge Trouble Shotting
Gramps544
01-08-2003 09:48:32
I have a I-544 Tractor. It has a non-functioning temperature gauge. How do you trouble shot this device? Also can parts be replaced, or do you have to replace the whole gauge as a unit. It looks like the sending unit is non-removable from the gauge assembly.
Geoff
01-08-2003 14:00:34
 Re: Temperature Gauge Trouble Shotting in reply to Gramps544, 01-08-2003 09:48:32
Havn't seen you on recently.Take the whole unit out and put the sensor in really hot tap water. It
should read around 140 degrees or just a bit low on run. If it doesn't you'll have to replace the whole thing. good luck Geoff
Gramps544
01-09-2003 05:14:44
 Re: Re: Temperature Gauge Trouble Shotting in reply to Geoff, 01-08-2003 14:00:34
I was afraid of that. With my tractor running the needle does not move. A new whole gauge is in order then.
