Radiator-1206-806
Adam W
01-19-2003 16:23:51
Does any know if a 1206 radiator will fit on a 806 or are they different sizes, they look the same? Both are diesel. My neighbor did not think they would, beleived the 1206 was wider but not sure.
Paul
01-20-2003 04:20:23
 Re: Radiator-1206-806 in reply to Adam W, 01-19-2003 16:23:51
The rad will bolt right in it's exactly the same from both tractors.
scottAR
01-19-2003 18:08:31
I remember this discussion couple of weeks ago here about an 856-1256, 966-1566 and the larger tractors have a thicker core but same bolt up dimensions.
RPM
01-20-2003 06:29:47
 Re: Re: Radiator-1206-806 in reply to scottAR, 01-19-2003 18:08:31
Radiator from 806/856/1026/1206/1256/1456 will all interchange, no 66 will fit.
garry_sc
09-21-2004 07:11:36
 Re: Re: Re: Radiator-1206-806 in reply to RPM, 01-20-2003 06:29:47
Is this true for real?????
I have a 1026 and need a Radiator BADLY!
Anybody know where a rebuilt or new one can be found for a 1026?
garry sc_fxdxt@yah00.c0m
Larry B
01-20-2003 06:43:56
The books I have say a 1206 & 1256 radiator are bigger than 806-856. Are the deminsons the same only thicker core maybe? That should mean better cooling on the 806 right?
RPM
01-20-2003 11:42:16
 Re: Re: Re: Re: Radiator-1206-806 in reply to Larry B, 01-20-2003 06:43:56
Yes, they were thicker cores.
