Will these sleeves fit a Farmall M ???
gottago
02-25-2003 18:29:08
Trying to get a little more horsepower for my 1950 Farmall M, not for pulling at fairs or such just for working it everyday.
I am wondering if the sleeves and pistons from a Super M will fit in my standard M without boring the block. Or if the block can be bored to accept the bigger size sleeves without messing up my good block.
I am looking at a set that is for sale now in the ad section here, the seller is not sure if they will fit in a M block or not. He said that he thinks the pistons are 4 1/8" diameter.
Any and all help would be much appreciated.
The link to the item for sale is attached.
Thanks to all
gottago
Red Rider
02-25-2003 19:29:11
 Re: Will these sleeves fit a Farmall M ??? in reply to gottago, 02-25-2003 18:29:08
No, The sleeve and piston set for a Super M block (264) will not fit your M. How ever you can get a sleeve and piston set for your M to get 264 Cu. To get 4 1/8 sleeves in your M block you will have to bore it.
