3288 Height
Bud
04-04-2003 08:49:55
Does anyone know the overall height with cab for a 3288 without FWD? Eldon , you gave me a height of 112 inches a while back but I'm not sure if that was the highest point including the cab?
Thanks
Devender
06-17-2004 21:43:20
 Re: 3288 Height in reply to Bud, 04-04-2003 08:49:55
what is the size of oil seal used in AL 3288
mikeinmo
04-04-2003 19:58:28
Checked my owner's manual and 112 inches is correct to top of cab. That is with 18.4x34 rear tires which came standard. My 3088 has 38's and it seems to add quite a bit of height but I don't know exactly how much. Hope this helps.
Eldon
04-04-2003 15:48:15
That 112" figure can from a sales flyer on "30" series tractors. It's listed as "height over control center". I have a 186 hydro. The sales literature on that says 112" to top of cab. It actually measures real close to that. A 3288 FWD is probably a pretty rare puppy. Rear tire size would be the same with 2 or 4 wheel drive, so cab height should be real close. Hope this helps!
