Can I use 4 1/8 pistons/sleeves in a 248 Farmall M
gottago
04-13-2003 23:23:58
My tractor is a 1950 model with the 248 engine.
I want to re-sleeve it and install a set of Firecrater pistons. I have a set of 4 1/8" pistons and sleeves that were removed from a Super M. The sleeves measure 4 1/8" inside and 4 1/4" outside.
Can my block be bored out to accept these sleeves, with out getting into the water jacket?
I have been told that I can remove the old sleeves and hone the cylinder walls and install these pistons without using any sleeves at all.
I am not sure of this advice and do not want to screw up a good block, the serial number on the engine matches the number on the tag.
If they cannot be used, I guess that I will sell them and order a new set that will fit.
thanks
gottago
Red Rider
04-14-2003 20:05:43
 Re: Can I use 4 1/8 pistons/sleeves in a 248 Farmall M in reply to gottago, 04-13-2003 23:23:58
You could safely on a new 248 block. It will all depend on how much erosion there is on the water jacket side of your cylinder wall.
randy hall
04-14-2003 00:11:54
i have bored several m's to take the 4 1/8" sleeves with no problems.
