Hydraulic Pressure H vs 300
GooseCreek Farm
04-18-2003 04:36:21
What type of hydraulic pressure (psi ?) do you get out of an "H" lift all vs a "300" hydraulic system? Just bought the "300" and connected it to a (1) hose cylinder with an implement attached and blew oil out the relief hole. It's an old aftermarket cylinder, which seem to work fine on the "H". Does the "300" have to much oil pressure for it?
Matt K.
04-18-2003 09:17:33
 Re: Hydraulic Pressure H vs 300 in reply to GooseCreek Farm, 04-18-2003 04:36:21
We have had older cylinders on equiptment that
would do that frequently.I believe the seals
must start to go bad,and let oil get by to the
back side of the piston.They will squirt a stream
of oil for a few seconds when fully raised since
the oil is squeezed with no way out.
Just a thought.
Matt K.
04-18-2003 09:16:46
Just a thought.
ih_bug
04-18-2003 08:33:04
the relief hole on the tractor or is there one on the cylinder?
Steven@nd
04-18-2003 05:24:41
H would have about 850 psi maximum if the pump is in good shape. I believe the 300 had around 1200 psi.
Not too much difference, but I think enough to finish off a weak cylinder...
Hugh MacKay
04-18-2003 20:16:00
 Re: Re: Hydraulic Pressure H vs 300 in reply to Steven@nd, 04-18-2003 05:24:41
Steven: I would question if the difference is any. On our farm we bought in order Farmalls H, 300, 560 and 656. The only one that ever matched the H for hydraulic lift was the 656. My dad had a loader on H from new. When he bought the 300 new, he wanted to change the same loader from H to 300 for the live hydraulics. The IH dealer spent countless hours trying to make that loader lift what it would on the H. It never happened.
The 560 and 656 never did have the same loader as we went to a 2000IH. 560 was no better than 300. 656 was only marginally better than the H. I should add that the 560 was 15 years old and 656 was 8 years old before a loader was on either.
