Warm air intake flapper?
gordy
04-19-2003 09:09:51
i have a 1965 706 gas. the manifold has a warm air gate valve to let exhaust heat intake air. outside the manifold there is a coil spring on the valve pivot shaft that has gotten too weak to move the flapper. the local ih dealer hasn't been of much help. i have two questions. 1)can anyone tell me which position(cw or ccw) the flapper/pivot shaft would be in for heating the incoming air(open?). when i manually turn the shaft cw the coil spring winds up tighter. 2)anyone know where i can get a new spring? thanks
gordy
04-20-2003 05:48:59
 Re: warm air intake flapper? in reply to gordy, 04-19-2003 09:09:51
thanks for the info CNKS. can anyone explain how those thermal springs work. do they want to wind up when they get hot or do they want to unwind.
CNKS
04-19-2003 09:26:20
Try Carter and Gruenewald, Bates Corp, or Steel Wheel Ranch.
