Farmall M v8
Don LC
04-19-2003 10:40:17
I have posted, asking for information on this subject before....I got "opinions" ....I want use ful information, places to buy books and ideas and guys that have experance doing this..... I have seen several at shows but, I know It has been done.....I have built many street rods, so I know what I am getting into....I could go it alone, but I though I would ask around before buying a bunch of parts...the tractor will bee used too pull wagons and shows...I did this years ago using a pinto in a H = more speed getting wagons to and from the barn.....
Jason Knuth
09-01-2004 10:28:45
 Re: Farmall M v8 in reply to Don LC, 04-19-2003 10:40:17
I built a Farmall M with a 440 mopar and a 727 automatic hooked into the farmall's five speed. one of the main things when putting that much power in a farmall M is that you need some good brakes. get ride of the band brakes and set it up for disc brakes. other wise when are under a hard pull and you want to keep it going straight down the track the bands can lock up at times which can cause alot of trouble.
REDMAN
04-19-2003 20:24:05
I don't know how to do it,but I know of 2 that are in the red power round-up book,the first one
troy casper from arlington,south dakota
the second is
norm sevcik from northfield minnesota.
Both of these tractors look really good. good luck
Tractor Dan
04-19-2003 18:45:09
a guy that used to pull the rainbow worrier his name was Wayne Keefe he started pulling with a farmall M with i believe a 400 small block with a hyramatic transmition hooked to the 5 speed farmall trany he said it would fly down the road he was from connticut but lives in vermont now
