Farmall B water leak
Kent
04-23-2003 14:20:07
Just purchased a B that has a steady stream of water coming out the lowerside of the bellhousing. I assume freeze plug needs replaced? No water in the oil. Any suggestions or tips on splitting the tractor?
C. Amick
04-24-2003 09:40:03
 Re: Farmall B water leak in reply to Kent, 04-23-2003 14:20:07
I don't recall any freeze plugs located on the block inside the bell housing. I will have to look at the engine sitting in my garage. Are you sure it's not running down from above?
Trigger
08-05-2004 13:05:40
 Re: Re: Farmall B water leak in reply to C. Amick , 04-24-2003 09:40:03
I am buying a Farmall B and the guy said that it had a water plug out ..and it's inside the case.
I would dance a jig if I did not have to split this thing...
Trigger
