Order Farmall Cub Parts Online
CUB dist rotor gears
Joe
04-27-2003 07:55:15
Any one have a good source on-line to buy a rotor and rotor gear set for an older CUB distributor. This is a J4 type mag distributor where the rotor has external gear teeth and contacts a small gear that attaches to the main distributor shaft.
thanks
joe z.
Tom in Illinois
07-02-2003 06:53:06
 Re: CUB dist rotor gears in reply to Joe, 04-27-2003 07:55:15
I was just about to post a note on this very same problem and I saw your note. I have a 1948 Cub (at least that's what the serial number says). I have the same problem. I go to my local IH dealer and they have sold me two rotors and neither look like this. I am beginning to think the mag/distributer may not be for a 1948. I sure would like to know more about this too. I have some badly worn teeth on the rotor and even a tooth missing on the metal gear. I should replace them both before putting it back together.
