454 Steering wheel came off in my hands!
Truck
05-29-2003 10:17:51
I was out back moving some stuff around the yard and my trusty 454 steering wheel came off in my hands when I pulled upwards on it, along with an oily splined shaft. It is power steering, and it was making a nasty cracking noise just before this happenned. I was trying to see if there was more slop than normal and it seemed to have LOTs of upward free play:-)
What am I in for to fix this? Is it a simple take off the upper shaft, replace a snap ring, and go on my merry way? Or is it a deeper problem than it appears?
Diesel Bob
05-29-2003 12:54:43
 Re: 454 Steering wheel came off in my hands! in reply to Truck, 05-29-2003 10:17:51
it sounds like the bearing in the steering column leading down to the orbitol unit has failed not a common fault but have come across it before it will mean a new or s/hand part will be needed bit of a fiddle to change but not over complicated there is a couple of cheats if you are interested
GORD CRAIG
12-14-2005 00:32:29
 Re: Re: 454 Steering wheel came off in my hands! in reply to Diesel Bob, 05-29-2003 12:54:43
DOES ANYONE KNOW WHERE TO GET STEERING BOX PARTS FROM.I NEED TO GET THE SPLINE GEAR THAT THE SHAFT GOES INTO .A NEW BOX IS $1600.00
