560 paint color
dvtw
06-16-2003 10:57:47
I was wondering what the tin work that runs just under the hood along the sides with the emblem attached to it on a '61 560 gas would have been from the factory? Is is white or a creme color? I've seen repaints both ways and wondered which is correct. Thanks,
David
sammy the RED
06-16-2003 19:33:54
 Re: 560 paint color in reply to dvtw, 06-16-2003 10:57:47
IH-901 is the correct color.
Available from PPG.
Diesel Breather
06-16-2003 18:45:55
The origional color for the 560 white was an off white, IH #901. The problem is it has been discontinued. The 935 white is the type of white used on the IH 66 series and up. You can get the match from a ppg paint supplier to mix it.
Aaron
06-16-2003 12:10:29
Color should be IH 935 White, an off-white, kind of cream color. Available at any Case-IH dealership in spray cans, quarts, and gallons.
wgatewood
06-16-2003 20:04:14
 Re: Re: 560 paint color in reply to Aaron, 06-16-2003 12:10:29
AARON YOU ARE WRONG ABOUT THE 935 WHITE IT WAS USED ONLY ON THE 66 SERIES AND UP TRACTORS THE CORRECT COLOR IS 901
dvtw
06-17-2003 06:16:12
 Re: Re: Re: 560 paint color in reply to wgatewood, 06-16-2003 20:04:14
Thanks for the responses. Who carries PPG paints?
