Will a draw bar support from 300 work on H ?
Kelly C
06-16-2003 18:23:02
Well I tell ya. This last week and a day has been awfull. I am breaking every thing I touch.
I broke the draw bar support under the tractor on my H. ( dont ask)
Any way can I take the one off my 300 and put it on?
The bolts are bigger and the draw bar itself is bigger. I was just going to take it off and check but I need to buy a thin wall socket to get the last bolt loose.That would really get me going if I spent 10 bucks for a socket and then it dont fit.
Jim
06-17-2003 07:26:04
 Re: Will a draw bar support from 300 work on H ? in reply to Kelly C, 06-16-2003 18:23:02
It will fit. We put the mounts off the H on the 300's all of the time. 300 mounrs are very hard to find.
Hugh MacKay
06-17-2003 03:07:17
Kelly: Just kind of curious what you are refering to, either the part that swinging drawbar hooks to or one of the axle housing clamps? When you say under my first thoughts are swinging drawbar pivot. However your description sounds a bit like axle clamp. The axle clamp should work. That part on belly for swinging may have different size holes or even a different hole pattern. I can see that part on belly of torque tube being beefed up on 300 as it was not only loaders that broke H torque tubes. I can remember years ago an H having roller on swinging drawbar break with a heavy loaded trailer, and it broke a section out of torque tube rather than swinging drawbar or that mounting part breaking.
Kelly C
06-17-2003 05:04:45
 Re: Re: Will a draw bar support from 300 work on H in reply to Hugh MacKay, 06-17-2003 03:07:17
Thanks Hugh.
Its the part the swinging draw bar hooks too.
Its made of cast iron and snapped right in half.
I was just trying to put my draw bar back on after removing my mower. Must have had a hair line crack in it.
Needless to say it broke at the worst time it could have. My hay is all in nice windrows and collecting rain as we speak :-(
KX
06-17-2003 07:04:19
 Re: Re: Re: Will a draw bar support from 300 work in reply to Kelly C, 06-17-2003 05:04:45
Kelly that drawbar support is not cast it is forged. You can weld it. I don't own one that hasn't been welded somewhere. I know you just bought that new stick welder....crank it up and bond that thing back together. Some 7018 and a steady hand can make two pieces one, forever.
