Hydraulic lift capacity
Ken Middleton
06-17-2003 03:19:50
I have a Farmall/IH 706 tractor, Im wanting to find out the lift capacity on the hydraulic 3point hitch. If you have any info please let me know.
Thanks
Ken
Hugh Mackay
06-17-2003 08:09:59
 Re: Hydraulic lift capacity in reply to Ken Middleton, 06-17-2003 03:19:50
Ken: I forgotten this for sure but Cat II hitches somewhere between 4500 and 5000 lbs. I know my 656 just played with 3500 lb. sprayer. That rating is also looking at it from point that weight is centered on hitch pins. It reduces quite quickly for every foot the weight is back from pins. I had a liquid manure pump, projected close to 20' behind tractor. I'm thinking it probably weighed less than a ton. It was just all Cat II hitch wanted on a lift. Cat III played with it.
