1468 V8 Engine
Coit Jenkins
06-17-2003 04:16:01
Would like original paperwork on this engine. It appears to me it's not running right. When it is started up cold, it smokes white out left and is running raw fuel out the left side. When it warms warms up, the smoke quits and the raw fuel quits. I understand there is no one who rebuilds the pumps. Does anyone know is there is someone who does this? What is the difference between a 9liter and this DVD 550? Are the interchangable?
Some think the problem is the cam which is no longer available for truck or tractor.
Tractor Dan
06-18-2003 04:11:34
 Re: 1468 V8 Engine in reply to Coit Jenkins, 06-17-2003 04:16:01
my friend has a 1468 i have many hours on this tractor when it starts it blows white smoke you have to remember when this tractor is not under load it only runs on 4 cylenders then when under heavy i mean heavy load will all 8 cylenders pick up
REDMAN
06-17-2003 19:21:00
TRY MID-WEST DIESEL INJECTION IN FORT DODGE IA
I DON'T REMEMBER THE PHONE NUMBER BUT I DO KNOW YOU WANT TO TALK TO LEE.THEY DO ALOT OF PUMP AND INJECTOR WORK ON STOCK AND PULLING TRACTORS IF YOU CAN'T BUY IT LEE CAN MAKE IT.
KEV
06-17-2003 18:50:51
I can help you if you need some pump or injector work done.I work in a authorized fuel injection shop.Don't of these pumps any more maybe 1 or 2 in a years time.Get some # off of the pump and E-mail me back with them and I will help you as much as I can.
Thank you
KEV
wgatewood
06-17-2003 04:40:50
this natural for these tractors to run white smoke out of the left banck of this engines until it gets warm. i own one of these tractors.
Randy in NE
06-17-2003 04:31:53
Your local Case\IH dealer should be able to give you the name of a place to re-build the pump and injectors. There is a Diesel Specialties in Sioux City, IA and Omaha, NE. Yahoo found the one in Omaha. The phone number is (402)330-0580. My brother owns his own business in South Sioux City, NE where he works on Cummins pumps and injectors. He will also work on the roosa-masters and the Model 100s on the older IH's. I have never heard him mention working on one off of one of the V-8s. A good repair shop will make the pump and injectors as good as the day they came out of the factory. You can also get what you pay for. If you go cheap you will get a cheap product.
