Leaky carb
Jon Schenk
06-17-2003 09:47:13
When I go to start my Cub and it turns over but doesn't satrt, my carb leaks. Is this a natural thing of what???!!!
Bus Driver
06-17-2003 17:51:21
 Re: Leaky carb in reply to Jon Schenk, 06-17-2003 09:47:13
Farmall Nut posts a good answer. A different technique may help, too. Try pulling the starter rod first, then pulling the choke actuating rod. As soon as the tractor fires, quickly push in the choke rod. This reduces the time that the choke is applied and drawing excess fuel from the float bowl.
Jon schenk
06-17-2003 09:48:35
I hope you can understand what I am trying to say!!!???
farmall nut
06-17-2003 10:29:49
 Re: Re: Leaky carb in reply to Jon schenk, 06-17-2003 09:48:35
sounds like you are choking it too much and causing it to flood. Try choking it less. If this does not help then the float level may be a bit too high and need adjustment.
