Implements bolts
John Montgomery
06-17-2003 15:13:48
Does anyone know if the various implements that are attached to the IH Cub Tractor use special bolts or did they use standard bolts.
Thanks.
John Montgomery
Phlogiston
06-17-2003 19:27:06
 Re: Implements bolts in reply to John Montgomery, 06-17-2003 15:13:48
Yes, all true and there are two lengths. Make sure you are not using the longer length when the implement needs the shorter bolt or you will break the bottom of the casting out.
Phlogiston
Bigdog
06-17-2003 16:04:46
Cub implement bolts have a tapered shoulder on the head.
Alvin NE WI
06-17-2003 18:18:46
 Re: Re: Implements bolts in reply to Bigdog, 06-17-2003 16:04:46
and they are to be had at Case-IH also.
