Noisy crosscheck valve on 350
Evan350
06-18-2003 07:17:16
On my Farmall 350, the valve mounted on the battery box emits a loud raspberry noise while a heavy implement (i.e., 1000lb. chipper) is being lowered. How loud is so loud that it may be a sign the valve needs service? The hydraulics are still tight, no leak downs (unlike my MF35 which drops an implement like a hot potato as soon as the engine is shutdown).
Aces
06-18-2003 10:24:12
 Re: Noisy crosscheck valve on 350 in reply to Evan350, 06-18-2003 07:17:16
That can happen just because of the load and if you give the engine more RPM it might quite,not uncommon.
